Inventor Forum
Reference part visibility problem
4 REPLIES 4
mattclarke
654 Views, 4 Replies
Hi
I am working on an assembly and idw, and my assembly has a number of reference parts in it.
Two patterns of reference parts are not appearing in the idw for some reason.
I can get them to appear by changing the view style to show hidden lines, and then the hidden lines appear and solid lines for all except the first instances also appear. When i turn off hidden lines, the hidden lines disappear leaving the solid lines of all but the first instances. Then if i change the reference data line style to try and show all the lines, they all now disappear again.
Hope i've explained this clearly - would really appreciate some help as i am completely stumped
Matt
4 REPLIES 4
Cadmanto
in reply to: mattclarke
Matt,
Can you post images of what you are seeing?
Are these parts that you are having issues with possibly just surface parts with no geometry?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
mattclarke
in reply to: Cadmanto
Parts are definately solids, and i have set them to Reference parts in their document settings
In the attached pictures, you can see the 3 states i outlined earlier.
pic1 - not there at all
pic2 - hidden lines and solid lines (except first instance)
pic3 - solid lines (except first instance)
Its meant to show a simple rail track for a preliminary layout drawing
Cadmanto
Matt,
Try RCing on the view and editing it.  Then under the "Display Options" tab, under the "Section Standard Parts"
Try selecting "Always".  I know these are section options, but I have seen this work in similar cases like yours.
Plus, have you tried other selections in this dialog window to see if they make a difference?
Best Regards,
Scott McFadden
mattclarke
Changed section standard parts to always, while the parts were currently visible - and the parts have disappeared again. Tried with never and obey browser settings, and no effect whatsoever.
Again if i change the style to hidden lines they come back again (see my earlier post)
I decided to change the margin to 100 to see if that made any difference, and now i have a new 4th state of visibilty!
still with parts missing, but different parts missing this time!
