Inventor General Discussion
Active Member
larry-leisure
Message 1 of 11 (257 Views)
reducing File-Size after converting from 3DS to IPN ? Please help.
257 Views, 10 Replies
05-13-2012 11:20 AM
My intention was to convert a 3DS-File into an IPN-File, to use it in Inventor.
As I did not managed to do this in Inventor, I importet the 3DS-File in CATIA V5 and convertet it into a CATIA-CatPart and from there in an IGES.
Then I was able to open it in Inventor and made a IPN out of it.
The PROBLEM: The orginal 3DS-File had 700 kilobyte but the actual IPN 54 MegaByte !
Can anybody help me to reduce it to a minimum ?
File attached to this message
Thanks in advance
Larry-Leisure
*Expert Elite*
JDMather
Message 2 of 11 (253 Views)
Re: reducing File-Size after converting from 3DS to IPN ? Please help.
05-13-2012 11:49 AM in reply to: larry-leisure
IPN?  or do you really mean an IPT file?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
larry-leisure
Message 3 of 11 (250 Views)
Re: reducing File-Size after converting from 3DS to IPT ? Please help.
05-13-2012 11:55 AM in reply to: JDMather
SORRY !
YES an IPT !!!!!
Active Member
larry-leisure
Message 4 of 11 (204 Views)
05-14-2012 01:21 PM in reply to: larry-leisure
Nobody here who want to help me ? :smileysad:
Active Member
larry-leisure
Message 5 of 11 (171 Views)
06-03-2012 12:28 AM in reply to: larry-leisure
Still nobody here who want to help me ? :smileysad:
Please !
vmichl
Message 6 of 11 (168 Views)
06-03-2012 02:12 AM in reply to: larry-leisure
Why not go the AutoCAD way? 3DSIN+SAVEAS
Please note that 3DS is a mesh (facetted) format so your IPT 3D model will become quite large. See also:
http://www.cadforum.cz/cadforum_en/convert-surface-mesh-model-to-3d-solid-body-tip8183
Vladimir Michl, www.cadstudio.cz
Active Member
larry-leisure
Message 7 of 11 (166 Views)
06-03-2012 03:40 AM in reply to: vmichl
Hi Vmichl,
Thanks for your answer.
As I am an absoloute beginner, my intention was that someone from the discussion group helps me to convert it.
My second whish was, that I receive a smallest possible file out of the original one, which can be opended with Inventor. No details necessary.
Is that possible ? Would you help me ?
That would be very kind of you
Best regards
Larry-Leisure
*Expert Elite*
JDMather
Message 8 of 11 (159 Views)
06-03-2012 11:39 AM in reply to: larry-leisure
3ds is not a very useful filetype.  I recommend you start over from scratch.
Active Member
larry-leisure
Message 9 of 11 (154 Views)
06-03-2012 12:02 PM in reply to: JDMather
Hi JDMather,
What do you mean with your sentence >I recommend you start over from scratch<  ?
Larry-leisure
*Expert Elite*
JDMather
Message 10 of 11 (152 Views)
06-03-2012 12:46 PM in reply to: larry-leisure
File>New
start sketching....
...in otherwords, start over in Inventor.
You might import the faceted geometry for reference, but only for reference.  Then delete it once you have enough critical information.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
