My intention was to convert a 3DS-File into an IPN-File, to use it in Inventor.
As I did not managed to do this in Inventor, I importet the 3DS-File in CATIA V5 and convertet it into a CATIA-CatPart and from there in an IGES.
Then I was able to open it in Inventor and made a IPN out of it.
The PROBLEM: The orginal 3DS-File had 700 kilobyte but the actual IPN 54 MegaByte !
Can anybody help me to reduce it to a minimum ?
File attached to this message
Thanks in advance
Larry-Leisure
IPN? or do you really mean an IPT file?
Why not go the AutoCAD way? 3DSIN+SAVEAS
Please note that 3DS is a mesh (facetted) format so your IPT 3D model will become quite large. See also:
http://www.cadforum.cz/cadforum_en/convert-surface-mesh-model-to-3d-solid-body-tip8183
Vladimir Michl, www.cadstudio.cz
Hi Vmichl,
Thanks for your answer.
As I am an absoloute beginner, my intention was that someone from the discussion group helps me to convert it.
My second whish was, that I receive a smallest possible file out of the original one, which can be opended with Inventor. No details necessary.
Is that possible ? Would you help me ?
That would be very kind of you
Best regards
Larry-Leisure
3ds is not a very useful filetype. I recommend you start over from scratch.
Hi JDMather,
What do you mean with your sentence >I recommend you start over from scratch< ?
Larry-leisure
File>New
start sketching....
...in otherwords, start over in Inventor.
You might import the faceted geometry for reference, but only for reference. Then delete it once you have enough critical information.
Sorry to disturb you again, but my computer seems to be not strong enough -> hang-up at every try.
Is it not possible that somebody from this group converts me the file to a reduced one?
Thanks in advance
Larryleisure
Edited by
Discussion_Admin
