So these parts are all just base features from imported parts?
In that case, your main options are:
1. If you have 2010, it is supposed to have the ability to re-orient
these solid bodies (I wouldn't know if it actually works since my boss
cancelled our subscription ;-( )
2. Use the feature recognition addin to turn these into parametric
parts with sketches first, then you can re-define the sketches and
features based on the origin planes and point.
3. Create an assembly and position the part in the assembly where
you want it, then derive that assembly into a new part file, possibly
also translating in/out neutral to permanently break the link to the
original part assembly.
As you might guess, these appear to go from easiest to hardest, IMHO.
Bob
stevemckenna wrote:
> It appears that by far and large that the parts have been located in
> assemblies with references to the part geometry, rather than the origin
> or planes. Its really driving me nuts, as I have always used the origin
> planes for things like orienting pipe or tubing angles at an offset
> angle. Grabbing part faces for this sort of thing is sometimes
> problematic. I have taken a pretty good look at most of the use
> incidences of these parts and I should be okay with a replace, but I
> won't be doing anything drastic. As I 'correct' the parts I will be
> ensuring that they do not blow up any of my assemblies. What I am really
> curious about, is there a method to move a 'base body' within a part
> file to get my imported base to center on the origin.
