Hello, I am working on a project in which I have to export it as a DWG (from .iam) to be used in Autodesk Architecture, and I am having difficulties with the Z-axis.
Essentially, I need to flip the z-axis 180 degrees. It is pointing down, so Architecture thinks that my assembly is upside down, which causes some havoc for me.
Does anyone have any ideas on how to solve this issue?
Solved by JDMather. Go to Solution.
Suppress the Grounded condition.
Add appropriate constraints between the assembly origin planes and the grounded part.
or
Place or Demote as a sub-assembly and set appropriate constraints between the origin planes.
