We have a user that has a mysterious red cicle symbol with a slash through it showing up on a draft in a model. I've attached a screen capture of it. Does anyone know what this means? The drawing isn't showing any other errors but this symbol won't go away.
Is that a visible WorkPoint?
That's what I thought it was a first but it shows up outside the model when it's rotated and all the work features are off. According to the user, it shows up on the assembly too.
Go to Tools>Application Options>General tab and set Annotation Scale to 5.
Did it suddenly get much bigger?
If so, attach new screen capture here.
Adjusted the annotation scale - no change in the symbol. See attached Model_Circle_2.jpg.
Any clues in your model tree? Anything that looks out of place? Maybe expand all children and see if something sticks out?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Did you ever find a solution to this red circle symbol? I am having this same thing happening to me right now and I did a search and found this post.
Attach *.ipt file here.
Did you create this part or is it inherited?
Is this part imported?
Can you post the part?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I saw that one myself a couple years back. I don't think I ever figured out what it was ... can't even remember what model it was anymore or I'd go take a look at it again.
Rusty
Just went to open the file to look at it before I attached it and the symbol was gone!??
Thank you for the reply though!
Daniel
