Good morning,
I am trying to find a way to make a hole pattern along a curve, but the problem is my pattern is not a curve but rather a path along a precise angled path. Inventor does not seem to want to acknoledge this as a path aside for the first segment. Any suggestions would be appricaited.
Solved by JoAnn_Hogan. Go to Solution.
Now that I see where you are going with this - I think there might be an easier solution.
What you really have are 2 true Rectangular Patterns.
Here is a example I did in another CAD program.
See if you can reproduce in Inventor (if you can't, I'll give it a try).
Here is a pattern I am after, as you can see the holes have to fit within the round plate and if they do not fit must be removable ( can not have partial holes as in your example) There are also other features that pop up so the ability to remove individual holes to make room for these features is paramount. I want to be able to constrain it so the pattern angle (30 deg in this case) , hole spacing and dia can be updated with the need to update as few features as possible.
You've already spent enough time on this, so if nothing comes to you right away do not worry. I am actually a very new Inventor user (training booked for next week) and we have a consultant coming in next month to figure all this out with me, at this point I'm just trying to get ahead of the game.
( can not have partial holes as in your example) There are also other features that pop up so the ability to remove individual holes to make room for these features is ...
Delete Face with Heal
or
Suppress instance.
@Anonymous wrote:
.. we have a consultant coming in next month to figure all this out with me, at this point I'm just trying to get ahead of the game.
You will get the most out of this if you go through these.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inventor
Here is a link to an iLogic approach to keeping a pattern inside a boundary. There are a few caveats so read the entire text before applying. I've used this a few times to make perforated screens with odd shaped boundaries. It's great! Cheers.
http://www.cadlinecommunity.co.uk/Blogs/Blog.aspx?ScoId=43d32ea9-aba1-43a2-b7a5-e992c051a21c
