In sketech mode (Inventor 2014), I drawn a rectangle but found there are no any Parallel & Perpendicular & Horizotal Constraints in the rectangle.
It only heppens today.
I have checked the settings in the "skecth" or "part" tab in "Options" but found nothing to do with it.
Your helps are much appreciated.
Solved by johnsonshiue. Go to Solution.
Hi! It sounds like Constraint Persistence option is turned off. Hover the cursor to "Constraint Persistence" option in Constraint section -> press it. After that, the newly created rectangle should have appropriate constraints.
Thanks!
Exactly!
Thank you so much.
