Inventor 2013 part file attached.
I am trying to get the rectangle pattern to form 8 blades of the same shape and height across the barrel.A picture shows how the height is lost within the barrel..The only blade which is the same height is the 2 outside blades
Is the rectangle the right tool to produce the result?
Terry
This same question has come up here several times in the past - is it a class assignment?
A search should turn up the solution. As I recall there is a bit of a trick.
The CADWhisperer YouTube Channel
No it is not a classroom assignment just something i want to learn to do.
I have made some progress.Should the blades be equal distances between each other...sketch shows different distances even though the 2 outside blades are same
Terry
