What equation do i use in the Rectangle Pattern Tool so that Extrusion-1 has 9 occurences and that the last (number 9) finishes in the same spot as the first Extrusion on the opposite side
Inventor 2014
Ray
Solved by admaiora. Go to Solution.
Hi Ray, it's not clear your intent, the path, the orientation...
Can you attach a drawing of your final desired result?
Admaiora
Hi Ray,
this should help you
Admaiora
Hi Ray,
here a video and attached the part (Inv 2013)
Admaiora
