Inventor Forum
rectangle pattern
5 REPLIES 5
Terry__Close
466 Views, 5 Replies
rectangle pattern
Inventor 2013 part file attached.
I am trying to get the rectangle pattern to form 8 blades of the same shape and height across the barrel.A picture shows how the height is lost within the barrel..The only blade which is the same height is the 2 outside blades
Is the rectangle the right tool to produce the result?
Terry
5 REPLIES 5
JDMather
in reply to: Terry__Close
This same question has come up here several times in the past - is it a class assignment?
A search should turn up the solution.  As I recall there is a bit of a trick.
Terry__Close
No it is not a classroom assignment just something i want to learn to do.
Terry__Close
JD,no luck with the search.Do you remeber the trick?
Terry__Close
Would anyone know how to create this rectangle pattern please?
Terry__Close
I have made some progress.Should the blades be equal distances between each other...sketch shows different distances even though the 2 outside blades are same
Terry
