Inventor General Discussion
Valued Contributor
0 Kudos
Post 1 of 6
rectangle pattern
284 Views, 5 Replies
12-07-2012 03:48 AM
Inventor 2013 part file attached.
I am trying to get the rectangle pattern to form 8 blades of the same shape and height across the barrel.A picture shows how the height is lost within the barrel..The only blade which is the same height is the 2 outside blades
Is the rectangle the right tool to produce the result?
Terry
2,129 Kudos
Post 2 of 6
Re: rectangle pattern
12-07-2012 04:19 AM in reply to: Terry__Close
This same question has come up here several times in the past - is it a class assignment?
A search should turn up the solution.  As I recall there is a bit of a trick.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
0 Kudos
Post 3 of 6
12-07-2012 04:38 AM in reply to: Terry__Close
No it is not a classroom assignment just something i want to learn to do.
Valued Contributor
0 Kudos
Post 4 of 6
12-10-2012 06:02 AM in reply to: Terry__Close
JD,no luck with the search.Do you remeber the trick?
Valued Contributor
0 Kudos
Post 5 of 6
12-11-2012 03:33 AM in reply to: Terry__Close
Would anyone know how to create this rectangle pattern please?
Valued Contributor
0 Kudos
Post 6 of 6
12-12-2012 04:47 AM in reply to: Terry__Close
I have made some progress.Should the blades be equal distances between each other...sketch shows different distances even though the 2 outside blades are same
Terry
