Inventor Forum
Record a macro in autodesk inventor ?
10 REPLIES 10
Message 1 of 11
doran123
6628 Views, 10 Replies
I can't figure out how to record a macro. Is it really impossible ? I can't imagine such a good soft not to have such a common fonction ?
Thanks for your help.
10 REPLIES 10
Message 2 of 11
mcgyvr
in reply to: doran123
No you cannot record a macro.
BUT you can write coding for it.
What are you trying to do?
There are already alot of addins,etc.. out there already.
Message 3 of 11
doran123
Hu, I've got a *lot* of things to do, since I am re-designing a complicate part I made first with SolidWorks™.
I already coded a few macros with Solidworks™, and I'd like to convert them.
The macros import points from Excel™, create planes and 2D/3D sketches from these points and then create surfaces from these sketches, and eventually add constraints.
Thanks in advance for your help.
Message 4 of 11
Josh_Petitt
this probably can't be done by a recorded macro, even if you could record them. Did you record these macros with SW? Also, can you just use the SW part directly? (i.e. export from SW, then import into IV) You might look over in the Inventor customization group for more answers.
Message 5 of 11
ericp-theelf
I have done similar work in Solidworks, but have not needed to convert anything to Inventor. I would say that your best bet, and yes it will be some serious work, but go through your Solidworks macros and identify commands and objects and find their equivalent in the Inventor API and re-write the macros in Inventor. Sounds painful, but no other options exist in Inventor.
Message 6 of 11
doran123
Ok guys, thanks to all for your help.  🙂
Message 7 of 11
doran123
Just thinking about it : I digged the web looking for inventor macros tutorials, but could not find much.
I'm especially looking forward creating folders, moving items into them and changing names of items.
Thanks in advance.
Message 8 of 11
petercharles
Suprised you couldn't find much? Anyway, for a start you can follow these links
http://discussion.autodesk.com/forums/forum.jspa?forumID=120
http://modthemachine.typepad.com/
http://www.mcadforums.com/forums/ Edited by: petercharles on Nov 8, 2008 11:32 AM
Message 9 of 11
doran123
Wonderful ! You're great !
Message 10 of 11
s9anturu
Hello, I just want to record the macro and impliment the generated code in other software..just to make an automation..is that possible through autodesk inventor
Message 11 of 11
Frederick_Law
First reply above: No.
Even SW macro record can't record everything.  It only work on very simple commands.
Start here to learn how to write macro:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-BDDB44A3-3415-44EB-B10E-216BB08BD614
