Can someone recommend a thorough user's manual and/or reference book for programming with iLogic? I've seen several of the snippets posted in this forum and I often see objects and parameters being used that I didn't even know existed. Is there such a book, or is the internal help sufficient to exploring and learning most of the functionality?
So I am sure you have seen these videos.
I am not aware of a good book on iLogic either but there are several related posts on the newsgroup ( post1, post2 and post3)
Did you check out David Melvin's AU class on iLogic ?
Anything in particular you want to write in iLogic that we could help with?
Bob
Hi, Kindly find the link, which may be useful to you and for all..
I am still in the process of learning Ilogic....so the excel file will have updation.......based on my learning....and search....
I have not updated the excel file afterwards, in case if i update, i do update in Grabcad Website.
Kindly check the below link to download Ilogic Examples.
https://grabcad.com/carthik-1/projects
