Inventor General Discussion
sbrusco
Message 1 of 26 (4,506 Views)
Recommended Graphics Cards for Inventor
4506 Views, 25 Replies
01-23-2014 05:56 AM
Hi All,
Please forgive my ignorance of graphics cards but the card recommended by Autodesk for running Inventor is
"MS Direct3D 11 capable or higher; 512 MB or equivalent"
...and the quotes I got for computers list
2 GB NVIDIA Quadro K2000 (2DP and 1DVI-I) (2DP-DVI and 1DVI-VGA adapter) in the desktops
and
AMD FirePro M5100 w/2GB GDDR5 in the laptops
The provider "assures" me that these meet the spec but I just don't know. Can someone please shed some light and pull me out of the dark?
TIA,
Sal
Both are directX 11 and both are 2GB which is > 512mb
both "should" be just fine..
mcgyvr
Message 2 of 26 (4,488 Views)
Re: Recommended Graphics Cards for Inventor
01-23-2014 07:22 AM in reply to: sbrusco
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
sbrusco
Message 3 of 26 (4,476 Views)
01-23-2014 08:08 AM in reply to: mcgyvr
Thnx mcgyvr,
I knew someone here could and would help me.
Sal
LT.Rusty
Message 4 of 26 (4,467 Views)
01-23-2014 08:43 AM in reply to: sbrusco
Either  card will do just fine, but they're both really overkill in terms of price.
Get a mid-grade or high-end gaming card.  It'll be a LOT cheaper than the Quadro or FirePro, and it will handle Inventor just as well.
nVidia gaming cards of the current numbering scheme tend to have 3-digit model numbers, with some letters afterwards.  If you're looking at nVidia, look for a card with number XY0, where X is a number 6 or higher and Y is a number 5 or higher.  (e.g., 650, 760, etc.)
ATI cards are named as Radeon HD with some numbers afterwards.  Look for a card there with the number XYZ0, where X is a number that's 4 or higher, Y is a number 7 or higher, and Z is a number 5 or higher.  (e.g., 4870, 6850, 7770, 7950, etc.)
I'm using almost 6-year-old Radeon HD 4870's in my workstation at home (current up to date CPU / RAM / SSD though) and they're keeping up just fine with Inventor 2014 and even most games that I feel like playing at 1080p.
___________________________________________________________
Product Design Suite Ultimate 2013, 2014, 2015
Workstation: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / Radeon R9-270X 4GB
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
sbrusco
Message 5 of 26 (4,451 Views)
01-23-2014 10:05 AM in reply to: LT.Rusty
Thanks for your input LT. I will make your suggestion to our IT department and see what they say.
Sal
Active Contributor
Nelson_C
Message 6 of 26 (4,436 Views)
01-23-2014 10:56 AM in reply to: LT.Rusty
I don't recommend the gaming cards, we went that way first and burned a few out, and the workstation cards hugely outperform them in CAD as far as I could tell. I've been really happy with the AMD Firepro V5900 (can be found for around $400). We've been running these for 2.5 years. I couldn't justify the extra dollars for the Quattro with the same specs for triple the price. Here's a great list of workstation cards and specs: http://www.techarp.com/showarticle.aspx?artno=95
LT.Rusty
Message 7 of 26 (4,434 Views)
01-23-2014 11:04 AM in reply to: Nelson_C
Depends entirely on what you're doing with them.
Inventor uses Direct3D, not OpenGL.  The gaming cards will give you better performance at a far lower price-point with Direct3D applicati....  If you're burning up a graphics card using Inventor, then you've got some sort of hardware issue other than simply having a gaming card.
Think about it: these things are made for nerds in their mom's basement to have marathon sessions pushing demanding games.  Running Inventor for 8 or 10 hours at a time shouldn't push you very hard.  I see core temperatures and fan speeds on my card go higher with even older games - Portal, Half Life 2, Empire: Total War, that sort of thing - than I do with Inventor.
Active Contributor
Nelson_C
Message 8 of 26 (4,430 Views)
01-23-2014 11:18 AM in reply to: LT.Rusty
I'm only speaking from my experience. The gaming cards seem to run really hot (maybe pushing the limits more?) and so running for 50+ hours a week every week leads to higher failure rate. The workstation cards don't produce as much heat, its very possible that they are designed to be more reliable rather than constantly pushing the envelope like gaming card manufacturers have to. This might also be reflected in the workstation card prices. A 3 year old workstation card is pretty much the same price but a 3 year old gaming card is a fraction of the price as when first launched since 20 new versions of that card have come out since.
dgorsman
Message 9 of 26 (4,427 Views)
01-23-2014 11:36 AM in reply to: Nelson_C
The workstation cards are more designed for the visualation crowds, with extra features that enable them to do things like GPU rendering and real-time on screen work.  In order to do that they include more robust cooling systems.  That means they perform better when dumped into an ordinary box system.  You dump a high-end gaming card into an off-the-shelf box you may very well have cooling problems, as they aren't designed for the air flow required.  Gaming boxes have much better air flow and usually come with an extra fan or two which dramatically improve heat removal.  Both of those are necessary for the high-end hardware.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
sbrusco
Message 10 of 26 (1,792 Views)
09-03-2014 12:23 PM in reply to: sbrusco
Can someone point me to an Autodesk page that lists all the "acceptable" and "recommended" video cards?
