Inventor Forum
Recognizing AutoCAD 3D Solids (SolidWorks)
12 REPLIES 12
Message 1 of 13
dpiengineering
611 Views, 12 Replies
Is there an add-on or something that will recognize 3D data, say a STEP file or a 3D AutoCAD file, and build the data in Inventor? This would be similar to "Feature Works" in SolidWorks.
12 REPLIES 12
Message 2 of 13
in reply to: dpiengineering
There is Feature Exchange for MDT on the
second CD of AIS 6
as a trial version.
If you have MDT on your machine, you
can add the features to the model with
Feature Exchange and then import
the result to Inventor. Does only good
work with simple models.
I don't know whether this gives any
sense.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Is
Message 3 of 13
dpiengineering,
No, there is no "add on" as this is 'built in" as is.
Cheers.
> Thanks
Message 4 of 13
It is built in??? I know Inventor will recognize MDT models to some extent,
but it will not do STEP or a 3D AutoCAD file like the question asked.
"Kent Mathews" wrote in message
news:3DFEEBD1.C394D19@virtual.net.au...
> dpiengineering,
> Cheers.
> > Thanks
Message 5 of 13
Sure it will. You can import both STEP and AutoCAD solids. Click open and
select the file type to import. Click on options before you open to set the
options specific to each file type.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"Kim Myers" <---> wrote in message
news:0BEFD70B3E462CCA9064433AB07183A9@in.WebX.maYIadrTaRb...
extent,
> > dpiengineering,
> > Cheers.
> > > Thanks
Message 6 of 13
It will open the models, but will it recognize the features of a STEP model.
"Sean Dotson" wrote in message
news:3DE2F9D051AB167F619A35A042C4BC5F@in.WebX.maYIadrTaRb...
and
the
> Sean Dotson, PE
> extent,
> > > dpiengineering,
> > > Cheers.
> > > > Thanks
Message 7 of 13
Sorry misunderstood the question. You are correct. Feature based
translation is the holy grail in CAD translations...
Sean Dotson, PE
news:8FFC37C5A911901A127F954E58684FEC@in.WebX.maYIadrTaRb...
model.
> and
> the
> > Sean Dotson, PE
> > extent,
> > > > dpiengineering,
> > > > Cheers.
This
> > > > > Thanks
Message 8 of 13
You can look into some of the 3rd party services like elysium. I think they translate the native files from 1 system to another, not a neutral file like STEP.
Rich Thomas
Message 9 of 13
They still don't go natively to Inventor
however.  Supposedly in Q2 2003....
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
You
STEP.
Rich Thomas
Message 10 of 13
As an aside, did you know you can copy and paste an
AutoCAD sketch into SW.  Why can't we do this in IV???
Is
Message 11 of 13
Anyone checked out TTI, Proficiency, Aspire3D or any of the others? There was also some companies that used to take clean 2D drawings and convert them to MDT. Anyone have any experiece with that type of translation?
Rich Thomas
Message 12 of 13
yes,yep, un-hunh and a few others (Theorem, TIF,
Translation Technologies etc..)
We were researching ProE to IV native feature based
transfer.  So far no one that I have found has a feature based translator
that will go directly into IV.  As mentioned before you can use the Feature
exchanger but sometimes that can be a long process.
I think Elysium is the closest to having a product
to market, but it will be a few more months...(Proficiency was supposedly
working on one too but I haven't heard anything on it lately)
Sean Dotson, PE
Check the Inventor
Anyone
Rich
Thomas
Message 13 of 13
http://www.tenlinks.com/NEWS/PR/TTI/121702_sw.htm
Beat to the punch again.
Rich Thomas
