When preparing an assembly for export to a Revit family, all features need to be recognized as Revit features. I have a part which consists of a sweep with a 3D path, 2 planar sketches projected to a 3D surface to be precise. To make matters worse, it's a sweep whose end meets it's own beginning (the intent of this specific model is to just satisfy a shape, not necessarily reflect the way it's going to be produced). To date I have not found a way to have this sweep feature recognized as a Revit feature, be it as a single feature or multiple. Any help would be much appreciated. I am running Inventor Professional 2014 on Windows 8 64-bit.
Solved by pcrawley. Go to Solution.
Your options are a bit limited! You can either find a way - but it seems like you've exhausted that route. Or, take it into Revit as an ADSK format.
If you export from Inventor as ADSK, then you don't need to do any of the feature recognition. If it's an assembly, you shrinkwrap it, then export the part using the BIM Exchange tool. (You'll find .RFA is greyed out.) It's only if you want to give the Revit user a Revit Family file (.RFA) that you need to go through the pain of recreating your entire model using modelling features that Revit can recognise.
