Inventor Forum
Rebuild time comparison - volunteers wanted for 5 mins
47 REPLIES 47
Message 1 of 48
stevec781
2809 Views, 47 Replies
In my quest to find out how much machine specs can improve rebuild speeds I thought I would make a challenging part and see if anyone would be interested in comparing rebuild times.
Under the sweep edit sketch5 and change the dimension of 30 to 40.  See how long it takes to rebuild after you press finish sketch.
My machine takes 24 seconds in both 2011 & 2012.
Specs are
Windows XP64
Duo Core E8400 3.0 GHz
8Gb ram
Quadro FX 570 card.
Thanks.
47 REPLIES 47
Message 2 of 48
blair
in reply to: stevec781
I get 17 seconds.
Delta Tau Chi ΔΤΧ
Message 3 of 48
mrattray
in reply to: blair
18 seconds.
IV 2012 Sp1
Windows 7 x64
i-5 3.1ghz
8 gb ram
AMD Radeon HD 6670
Mike (not Matt) Rattray
Message 4 of 48
stevec781
in reply to: mrattray
Thanks guys, the I5 has a similar speed so maybe win7 is afactor there, but maybe its cache or something else as well.
I just over clocked to 3.41Ghz and am at 19 sec now.
Message 5 of 48
mrattray
Don't forget that IV only uses one core. My quad core basically runs IV at 1/4 strength (3.1/4~750Mhz).  I assume a "Duo Core" is dual, that means your running about twice as fast as me, at least as far as rebuilding in IV goes.
Message 6 of 48
blair
It comes down to the clock speed of a single core in the CPU when dealing with IPT and IAM files. If you could get a really fast single core CPU for IPT and IAM files, it would be all you need.
IDW creation with IV2012 does take advantage of multi cores, FEA and Studio also take advantage of multi CPU cores.
Delta Tau Chi ΔΤΧ
Message 7 of 48
markc-uk
in reply to: blair
Thought I'd have a go at this.
I'm using Inventor 2012 SP1 on windows 7 64 bit on bootcamp.
The machine is a 2011 iMac; Intel core i7 quad core 2.8 Ghz with 4Gb ram.
I got a shade under 15 seconds.
MarkC
Message 8 of 48
swalton
Minor nitpick: each core runs at full clock speed.  So IV is using 1 core at 3.1 GHz.  You have 3 cores at 3.1 GHz for all the work you can do while waiting for IV to finish calculating.
Steve Walton
Inventor 2023
Vault Professional 2023
Message 9 of 48
mcgyvr
in reply to: swalton
18.4 seconds
Message 10 of 48
coreyparks
in reply to: markc-uk
18.5 seconds here Intel Xeon Processor W3530 @ 2.80Ghz
Pretty sad when the Mac beats us all, lol.
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
Message 11 of 48
blair
16.5 seconds on my home machine.
No overclocking, all standard settings.
Delta Tau Chi ΔΤΧ
Message 12 of 48
PACDrafting
16 secs.
Win 7 64 Bit
8G RAM
NVIDIA GeForce 560 Ti Video Card
Intel Core i5-2500 CPU @ 3.30 GHz, 3601 Mhz, 4 Cores(s)
128G SSD OCZ-VERTEX2 ATA Device
1T SAMSUNG HD103SJ ATA Device
Message 13 of 48
PACDrafting
Press the Rebuiild All button.
Do you get errors?
Message 14 of 48
SBix26
Home computer:
  Windows 7 64-bit SP1
  Athlon 64 3200+ 2.00 GHz (single core, five years old)
  6 GB DDR2 RAM @ 800MHz
  Radeon HD 5670, 512 MB DDR5
  Inventor 2012 SP1: 44 seconds
  Inventor ?: 40 seconds
Work computer, operating locally at home, but with design data, license and other projects located on work server, specs in my signature below:
  Inventor 2012 SP1: 26 seconds
Odd difference that I noticed in trying this on two different computers: on my work computer, it took as long or longer to re-solve the sketch after changing the dimension as it did to rebuild the part when I finished the sketch; on my home computer, the re-solve was to all appearances instantaneous.
Message 15 of 48
stevec781
in reply to: SBix26
I am new to overclocking so stopped at 3.56Ghz as that takes the ram to 800 and my ram is 800 so not game to go any faster.  Temps and volts are fine so going to stay at this overclock.  Still at 19 sec's tho.  Tried with the GTX 560 card no change.
I dont get rebuild error but I'll bet it's the workplane.  Whenever I create a workplane by selecting a projected 3D curve and its end point it fails randomly.  In one file 3 update fine, two fall over.  I have submitted a sample to my VAR, but no response yet.
I was hoping there would be a machine out there that would get under 5 sec but some of those specs are pretty good.  So it looks like I have found my bottle neck.  Although simpler, I have lots of sweeps that use normal to surface option.  So until we get multi core processing or significanlty faster CPU's it's going ot come down to workflow. (looks like Windows 7 might also take a couple of seconds off)
Its been an interesting test, thanks to everyone that participated.
Message 16 of 48
jeanchile
It sounded like this was sort of over but I was curious and this looked fun so.... 10.6 seconds FYI. (Desktop)
Inventor Professional
Message 17 of 48
in reply to: jeanchile
Desktop
64 bit Win 7 Ultimate SP1
Xeon quad 3.20 GHz
12 Gb RAM
AIP 2012 SP1
19 sec
Laptop (not intended for IV use)
64 bit Win 7 Home Premium SP1
Intel quad Core i3 @2.20 GHz
4 Gb RAM
25 sec
AIP 2012 SP1
Message 18 of 48
stevec781
No not over at all, the more results we get the better for helping us all (and hopefully Autodesk if they are watching) get the most out of our systems.  Interesting that your i7 smashes the others, then I notice every one else is using 2012.  Makes me wonder.
My overclock is faster but I am still heaps slower, so either there is more to the processors than just speed, or win 7 is that much better than XP.  And the laptop at 2.2Ghz is close to mine at 3Ghz.  Again Win7.
I might have to bite the bullet and upgrade to Win7, but the thought of finding my disks and reinstalling everything else doesnt excite me.
Message 19 of 48
jeanchile
I noticed my video card drivers were slightly out of date so I updated them and ran again.... 11.1 seconds Smiley Sad.
Then I tried my laptop and got 23.0 seconds... Smiley SadSmiley SadSmiley Sad
When I was looking for a new machine last year (the one I have now) I found this post interesting: http://ellipsis-autodesk.typepad.com/blog/2010/06/more-hardware-spec-goodness.html
Message 20 of 48
in reply to: blair
25 seconds on my laptop.
This is a great thread because it now gives me DATA that says it's time for a new workstation.
