I don't know, if that helps:
I was able to move the EOP marker fully up, and then down, step by step.
Only one problem with Fillet78
But when I tried to do a Rebuild All after that, there were a lot of errors,
first problem with Loft5. My system: IV6 SP2
Walter
"Patrick Berry" schrieb im Newsbeitrag
news:C344ED99A5166488C09CC16D0D82059B@in.WebX.maYIadrTaRb...
> This is the reason you should run "rebuild all" frequently while building
a
> part. Most build features don't force a rebuild. I think this is to
> improve the speed of the program. Often, there will be an error with a
> feature that doesn't show up until you do a rebuild all. Something that
> worked, but by all logic shouldn't have. If other features downstream
> utilize that feature, they will also fail with a rebuild all. The first
> thing to do is move the EOP to below the highest error. Try fixing the
> feature without changing or destroying the geometry, then slowly step down
> the EOP. This may automatically fix may downstream errors.
> I have also had a few cases, especially in complex parts, where an
upstream
> feature suddenly became corrupted, causing a domino failure.
> Pat
> "MikeC" wrote in message
> news:6090D83F2754637E147EE4189508F257@in.WebX.maYIadrTaRb...
> > When I do a "rebuild all" to a large complex .ipt I get a long list of
> > errors to a perfectly fine file. Smaller, less complicated files are
fine.
> > Anyone else notice this?
