garyallisonatjoneseng,
Have a look through your file structure. Start at the lower levels
(ipt) files and work your way up the tree using the rebuild all command.
Your problem probrally exists further down the tree. It should
(assigning the culprit file is fixed) rebuild this file once you work
your way up in this manner.
It may be a derived part a number of levels down, as the cause, that can
not rebuild correctly. You need to help Inventor out with this one.
Hope this helps,
Kent Mathews
garyallisonatjoneseng wrote:
> When I use the 'rebuild all' command under tools I gat this message,
> !Invalid referance to segment object used.'
> Any ideas? Since this has started to happen I've had 5 crash's in 1 hour.
