Inventor Forum
Realistic Image issue
3 REPLIES 3
gcross
264 Views, 3 Replies
The two images in the attached JPEG show the exact same settings under lighting in style editor using the old Warehouse IBL at default settings.
The one on the right is really nice but it instantly turned into the image on the left immediately after I edited a part insert constraint to be up a little higher.
What is going on?
Gary
3 REPLIES 3
gcross
in reply to: gcross
Forgot to mention that the Realistic View interactive no longer occurs when rotating the model view.
Gary
mcgyvr
in reply to: gcross
Close the file and reopen it.. Then try it again..
Any raytracing issue I've had (parts not showing up..old parts still showing up even after they are deleted,etc..) has been fixed by just closing the file and reopening it. (maybe even try restarting Inventor if that doesn't fix it)
gcross
in reply to: mcgyvr
That did the trick, I usually resort to that at some point but usually after I post!
Thanks.
Gary
