Inventor General Discussion
Active Member
jbauer
Message 1 of 2 (145 Views)
Re-Sizable Panel
145 Views, 1 Replies
11-12-2012 07:33 AM
I was hoping someone could help me with the following issue.
I would like to make a aluminum framed panel template that I can enter in the height and width dimensions and then save the panel assembly into it's own unique part#. Right now, when I design enclosure, I will have multiple sizes of framed panel and I typically have to manually change the length and width dimensions for the individual extrusion members, then change the panel size manually. I re-name the new extrusions and panels to avoid file name conflicts. Is there a way to simplify the process?
Like I said before, I will have multiple "section"(SEC) assemblies in each main assembly file.
I attached a zip file with my aluminum framed panel assembly.
PaulMunford
Message 2 of 2 (128 Views)
Re: Re-Sizable Panel
11-12-2012 01:37 PM in reply to: jbauer
Look into skeletal modelling:
http://cadsetterout.com/inventor-tutorials/assembly-techniques-for-woodworkers-the-skeletal-modellin...
or iCopy:
http://cadsetterout.com/inventor-tutorials/autodesk-inventor-icopy-tutorial/
Copying an Inventor assembly has it's wn challenges. There's some good advice here:
http://cadsetterout.com/inventor-tutorials/the-secrets-of-copying-assembly-files/
Let us know how you get on!
Paul
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
