I was hoping someone could help me with the following issue.
I would like to make a aluminum framed panel template that I can enter in the height and width dimensions and then save the panel assembly into it's own unique part#. Right now, when I design enclosure, I will have multiple sizes of framed panel and I typically have to manually change the length and width dimensions for the individual extrusion members, then change the panel size manually. I re-name the new extrusions and panels to avoid file name conflicts. Is there a way to simplify the process?
Like I said before, I will have multiple "section"(SEC) assemblies in each main assembly file.
I attached a zip file with my aluminum framed panel assembly.
Look into skeletal modelling:
or iCopy:
http://cadsetterout.com/inventor-tutorials/autodesk-inventor-icopy-tutorial/
Copying an Inventor assembly has it's wn challenges. There's some good advice here:
http://cadsetterout.com/inventor-tutorials/the-secrets-of-copying-assembly-files/
Let us know how you get on!
Paul
