Inventor General Discussion
Valued Contributor
ccoomes
Message 1 of 7 (228 Views)
Re-Select Selected Items after Changing Dimension - VBA
228 Views, 6 Replies
02-25-2014 01:41 AM
I have some code that changes the text and precision of selected dimensions as follows:
'Set a reference to the select set of the active document.
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oDrawingDims() As DrawingDimension
Dim oItemsCount As String
oItemsCount = oDoc.SelectSet.Count
Dim oDimText As String, oDimPrecision As Long
oDimText = gDimText
oDimPrecision = gDimPrecision
If oItemsCount = 0 Then
Call MessageBoxes.NoDimensionSelected
Exit Sub
Else
Dim a As Long
a = 0
Dim i As Long
For i = 1 To oDoc.SelectSet.Count
If Not oDoc.SelectSet.Item(i) Is Nothing Then
If TypeOf oDoc.SelectSet.Item(i) Is DrawingDimension Then
a = a + 1
ReDim Preserve oDrawingDims(0 To a)
Set oDrawingDims(a) = oDoc.SelectSet.Item(i)
Else
Exit Sub
End If
End If
Next
Dim b As Long
For b = 1 To a
oDrawingDims(b).Text.FormattedText = oDimText
oDrawingDims(b).Precision = oDimPrecision
Next
End If
End Sub
The problem I have is that after it is modified the Dimension correctly, it de-selects all the items so there is nothing selected.
How can I add some more code in VBA so it will keep the selected items selected?
Please note that I did not create the code above, I copied if from the web and changed it to suit.  I can't remember who created the original code, but i has saved me a lot of time and effort.
If anyone can guide me on how to re-select the selected items that will save us even more time.
ADN Support Specialist
philippe.leefsma
Message 2 of 7 (198 Views)
Re: Re-Select Selected Items after Changing Dimension - VBA
03-03-2014 12:58 AM in reply to: ccoomes
Any transacted operation will clear the select set, for example modifying a dimension properties. You need to store the content of the select set before doing any modification. You can for example create and populate an ObjectCollection or a simple array of variants.
I hope it helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Valued Contributor
ccoomes
Message 3 of 7 (193 Views)
03-03-2014 02:20 AM in reply to: philippe.leefsma
Hi Philippe,
I did think it would be something like that.
I have tried to get create a Object Collection but I cannot work out how to re-select them and add them to it.
Could you please advise on the code needed to create the object collection, add the dimensions to it and then re-select the collection?
Clive.
philippe.leefsma
Message 4 of 7 (190 Views)
03-03-2014 02:27 AM in reply to: ccoomes
You create the ObjectCollection with TransientObjects.CreateObjectCollection. You should be able to find plenty of examples in the API Help Files.
ObjectCollection.Add to add objects to it.
You can re-select the objects with SelectSet.Select.
Philippe Leefsma
Valued Contributor
ccoomes
Message 5 of 7 (175 Views)
03-04-2014 12:13 AM in reply to: philippe.leefsma
Hi Phillipe,
I have tried to work out the VBA code by using the Inventor API Help and Examples and I cannot get it to work.
Would you be able to supply me the code to get the selected items into a object collection and then how to recall them?
There will normally be more than 1 item selected at a time.
Many thanks in advance for your assistance.
philippe.leefsma
Message 6 of 7 (172 Views)
03-04-2014 12:28 AM in reply to: ccoomes
How about that:
Sub DimTest()
    Dim doc As DrawingDocument
    Set doc = ThisApplication.ActiveDocument
    Dim collec As ObjectCollection
    Set collec = ThisApplication.TransientObjects.CreateObjectCollection
    Dim obj As Variant
    For Each obj In doc.SelectSet
        collec.Add obj
    Next
    For Each obj In collec
        If TypeOf obj Is DrawingDimension Then
            Dim drawDim As DrawingDimension
            Set drawDim = obj
            drawDim.HideValue = True
            drawDim.OverrideModelValue = True
            drawDim.Text.FormattedText = "ADN rules!"
        End If
    Next
       doc.SelectSet.Select obj
    Next
End Sub
______________________________________________________________
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Philippe Leefsma
Valued Contributor
ccoomes
Message 7 of 7 (167 Views)
03-04-2014 12:34 AM in reply to: philippe.leefsma
Hi Phillipe,
That is perfect.  I will modify the code to incorporate your method.
Many thanks you have saved us a lot of time and effort.
Thanks again.
