Inventor Forum
Re-ordering block Attributes
3 REPLIES 3
254 Views, 3 Replies
Hi,I have been struggling to re-order the attributes in the AutoCAD blocks. Everytime i edit a existing block or try to create a new block (part copied from other blocks and renaming it as a new block) the order in which the attributes are displayed is shuffled completely.
This happens because the reference created for each of the attributes gets changed once i try to edit a block.
I have tried options like 'BATTMAN' 'ATTSYNC' 'BATTORDER' but the problem is i have a bunch of blocks each with 96 -150 pins in them (Each pins has an attribute reference). So it is really pain using all the above mentioned commands to arrange all the attributes in Ascending order.
I have also tried to use some LISP scripts, followed some similar previous posts in AutoCAD forum but nothing seemed to be productive.
Any ideas on how to resolve this ?!
3 REPLIES 3
JoAnn_Hogan
Could you please post the drawing so I could have a look at it?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Cadmanto
Welcome to the forum.
Just so you know this is an Inventor forum for users that have questions or issues in Inventor.
It sounds like you are having Autoad issues.  If that is the case (not sure what version you are using)
you should post this in the Autocad forum.  See the attached link.
http://forums.autodesk.com/t5/AutoCAD/ct-p/8
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
in reply to: JoAnn_Hogan
Hi JO, For Instance, please check for the drawing attached.
I need to have this block's attributes re-ordered from Pin1-Pin90 in an ascending order.
Uday
