HI,
I'm making a drawing in Inventor and I have several views and details and sections. Throughout making the drawing, I've created and deleted views. Whenever I do this, say the first view I placed was 'L', and then I delete view 'L', and make a new view. Inventor automatically labels this view 'M' instead of 'L', even though I don't have an 'L' view. This has caused me to have big gaps in the lettering of my views. Is there a way to "reset" the lettering so Inventor goes back through and re-letters everything starting from 'A'?
Thanks for your help.
Solved by karthur1. Go to Solution.
Welcome to the forum.
See if this thread helps you.
r-click on the arrow, select 'edit first text' or 'edit second text' depending on which arrow you want to update. Then you can use the 'add parameter' button to drop the view identifier into the text field.
