I generated a new part from an existing part along with it's idw. Then used 'replace model reference' in the new idw file to update the drawing views. Everytime I do this the ordinate origin point in a view turns magenta in color and 'design doctor' shows I have to re-attached the point. Problem is it still shows that the point needs to be re-attached no matter what I do. It is snapped correctly and dimensions are accurate.
Also, being able to delete the origin point would be nice. Maybe 2013 Inventor?
Thank you.
Pete
Can you able to share the model with us. I will test it out at my end to identify the problem. Do let me know, if you want to do a secure file transfer. I can provide an FTP for you.
