Is there any RAL/Powdercoat colourstyles available, or does anyone have recomendations on how to create them so the look as natural as possible.
Never mind about the RAL colour styles, I found it here
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=4497
However, how about powder coat apperance style
But still. The RAL colour pallete should be standard in the material/appearance library.
Oh yes it should.
Added to that, Inventor should also calculate with the thicknes of the powder-coat, since it can create problems if one does'nt take it in account.
@ENRAD Check out some of these search results and a few video results, they might point you in the right direction. Always be cautious when downloading from third party sites.
Here's how I used to accomplish this: If your powdercoater doesn't have digital files of all the colors to provide (mine did not) I would recommend taking your powdercoat samples (assuming you have a large ring of options like most places I've worked at do) and scanning them with the photocopier or going outside into natural light and taking a good photograph (which is what I did). Then create bump maps like the videos or searches show and generate your own powdercoat appearances to use. It is a bit more work but turns out a good looking product that matches what is actually physically available. If you can get the material looking good enough to fool people you know you're doing something right.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
