Inventor Forum
Raised Cabinet Door Design
9 REPLIES 9
Message 1 of 10
Bernie38
2650 Views, 9 Replies
Does anyone have any raised cabinet door design that they would like to share.  Am trying to figure out best approach in the design using Inventor.
Thanks  Bernie
9 REPLIES 9
Message 2 of 10
mpatchus
in reply to: Bernie38
Here's a basic raised panel cabinet door.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 10
Bernie38
in reply to: mpatchus
Thanks,  I was looking at dong it by extruding from the end then side.  This makes more sense.  Are there any Inventor Add-ins for this type of project?
Message 4 of 10
mpatchus
Not sure if there are any add-ins available.
I do a lot of woodworking and I've taken the time to create an iFeature for each of my router bits.
This allows me to quickly use one of my bits to create profiles for moldings, edge details, etc.
I just start with my wood blank, trim it to finished size, and apply the appropriate iFeature.
Do a search on YouTube for ifeatures.
Inventor 2025 Beta
Message 5 of 10
JDMather
I am not sure why Mike didn't use multibody solids techniques for his example, but I recommend checking out that technique for something like this.
Message 6 of 10
mpatchus
in reply to: JDMather
Multibody solids could be done of course, but for woodworking projects I tend to shy away from them.
I want each piece to be its own individual model.
At some point in the near future I plan on adding a CNC router table to my workshop and have Inventor drive the router.
Just need to come up with the $$$$.   lol
Inventor 2025 Beta
Message 7 of 10
LT.Rusty
That's not quite as simple as it sounds.  Hopefully it'll get better when the full version of HSM for Inventor comes out (HSMXpress is neat, but I need 3D capability), but in the meantime ...  right now my workflow is to create the models in Inventor, with extra sketches to define boundary areas for different operations; then export it as a STEP with sketches; import that into Visual Mill and hope like (insert warm place here) that it works because it doesn't, at least half the time; then set up my toolpaths; then post the G-code; then open that up with Mach3 (at home) or the ShopSabre program (at work), and then hope like (insert warm place here) there's no issues.
CNC router is fun, but getting my models to the CAM software from Inventor is a lot less fun.
(I have a ShopSabre 3636 at work and at Vision 2448 at home.  The Vision has been hacked to run Mach3 instead of the proprietary software.)
Rusty
Message 8 of 10
jsullens
You might want to check out Windom Tech on YouTube.  They take the multi-body Solid modeling approach and I believe they use a third party plug-ins to select wood and run interference checks etc.
http://www.youtube.com/user/WidomTech?feature=watch
Johnny
Message 9 of 10
waynefisher
Here is a fun project I am willing to share. This assembly has some good vba code and user interface for controling the door size, panel material, and door panel edge treatment. This should give you a good idea of how to proceed to build your own vba programs for your business. Any issues or questions reply here. Enjoy!
Message 10 of 10
KamDer
in reply to: LT.Rusty
There's a tool called Woodwork for Inventor that solves CNC related problems. It creates CNC programs automatically and you don't have to bother with all the manual programming.
You can check it out here:
https://www.woodworkforinventor.com/
