Inventor Forum
Radius Dimension to Diameter Dimension
3 REPLIES 3
hal1burn
3661 Views, 3 Replies
I have a semicircle feature that dimensions as a radius. I would like to change this to a diameter dimension. I know that I could use leader text but I would like to use a dimension instead. Does anyone know how to do this in 5.3? You could do it in Mechanical Desktop. Thanks.
3 REPLIES 3
in reply to: hal1burn
When creating the dimension, after selecting the
arc, RMB and under the "dimension type" pick "Diameter".  Or after the
dimension has been created, simply hilight the dim and RMB and change it at that
point.
Tags (1)
ptt50794
Is it possible to convert a radius dimensiont to a diameter once the dimension has been placed within a drawing view?
Is the easiest way to acheive this to delete the dimension and readd?
IgorMir
in reply to: ptt50794
So far - it is.
Web: www.meqc.com.au
