Inventor Forum
Radius and Diameter Default Formating
4 REPLIES 4
AnchorChain
836 Views, 4 Replies
The default format for a radius and diameter dimension is inserted with a prefix "R" and diameter symbol ahead of the measured dimension.  Our company standard pre-Inventor was to place either "RAD" or "DIA" after the measured dimension.  We can not seem to find anywhere in the setup to change how these type dimensions are inserted as a default or custom setting.
Can we change/customize the radius and diameter dimension formating?
Mechanical Engineer
Inventor 2014 Ultimate
Windows 8 Pro
4 REPLIES 4
IgorMir
in reply to: AnchorChain
May I ask on which National Standard your company standard is based on?
Igor.
Web: www.meqc.com.au
AnchorChain
ANSI
Mechanical Engineer
Windows 8 Pro
JDMather
ANSI uses R and ­Ø
cbenner
I see no way to change the default for these, but one can add a suffix in the dimensioning styles.... but then you'd have the Symbol up front and your text designation on the tail end.
I suggest you embrace the standards, it's always hard to walk away from "this is how we've always done it".
