Inventor General Discussion
Active Contributor
AnchorChain
Message 1 of 5 (294 Views)
Radius and Diameter Default Formating
294 Views, 4 Replies
10-31-2013 08:50 AM
The default format for a radius and diameter dimension is inserted with a prefix "R" and diameter symbol ahead of the measured dimension.  Our company standard pre-Inventor was to place either "RAD" or "DIA" after the measured dimension.  We can not seem to find anywhere in the setup to change how these type dimensions are inserted as a default or custom setting.
Can we change/customize the radius and diameter dimension formating?
Mechanical Engineer
Inventor 2014 Ultimate
Windows 8 Pro
Valued Mentor
IgorMir
Message 2 of 5 (266 Views)
Re: Radius and Diameter Default Formating
10-31-2013 03:21 PM in reply to: AnchorChain
May I ask on which National Standard your company standard is based on?
Igor.
Web: www.meqc.com.au
Active Contributor
AnchorChain
Message 3 of 5 (244 Views)
11-01-2013 07:01 AM in reply to: AnchorChain
ANSI
Mechanical Engineer
Windows 8 Pro
JDMather
Message 4 of 5 (239 Views)
11-01-2013 07:15 AM in reply to: AnchorChain
ANSI uses R and ­Ø
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
cbenner
Message 5 of 5 (223 Views)
11-01-2013 08:34 AM in reply to: AnchorChain
I see no way to change the default for these, but one can add a suffix in the dimensioning styles.... but then you'd have the Symbol up front and your text designation on the tail end.
I suggest you embrace the standards, it's always hard to walk away from "this is how we've always done it".
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
