Show only
Search instead for
using Animate, Tweak Component, how do I simulate a nut being screwed on
It appears you can have Transformation set to a direction X,Y,Z or Rotate
but not both together.
Or is it achieved in another setting.
regs
Do each tweak individually, then-
select Animate tool and click on the chevron in the lower right hand corner to expand the dialog box.
Select the two motions you want to combine (translational and rotational) and then select group.
J.D.
Thank you JD
"JDMATHER" wrote in message
news:9791248.1086636126685.JavaMail.javamailuser@localhost...
> In Animate click on the chevron in the lower right hand corner to expand
the dialog box.
> J.D.
