I am getting the following error while trying to save a drawing file. I
have both the assembly and the idw open and am in the process of doing a
revision. This assembly was originally created in R7. Note that the
migration utility was not run, I usually just open files and save to update
to the new version.
Any suggestions? I've been running R8 for about a week and have had a few
crashes. Mostly when using the undo command excessively (which I didn't
have a problem with in R7). Crash frequency seems to be on the order of 2-3
a day.
Have a great day
Aaron Miller
Greenfield Engineering, Inc.
aaronm & greenfieldengineering.com
[ERROR] Error(s) detected while writing segment AmGraphicsSegment in
database I:\GEI\CARRIAGES\HYSTER\H280HD\AO7366\46-1600.iam
[r:\core\rse\segment\segStream.cpp, line 244]
[ERROR] Internal error in persistence operation (Segment loading is not
supported within other persistence operations)
[ERROR] The database in I:\GEI\CARRIAGES\HYSTER\H280HD\AO7366\46-1600.iam
could not be saved [r:\core\rse\database\databaseC.cpp, line
1653]
