Hi All,
Yesterday I was experiencing problems with the refresh rates of models
migrated from 5.3 (i.e. models created from scratch in R6 display fine.)
I solved the display problem by re-installing Win XP Service Pak 1, followed
by a re-install of R6... However, at the end of day the display problem
reappeared! I then tried re-install of latest IV video drivers... with no
luck.
My System is as follows:
Dell P4 1.8 G Laptop
Win XP SP1
768 Meg Ram
NVIDIA GeForce4 440 Go
SOLUTION: Today I discovered (maybe a temp fix?)... if you change under
TOOLS: APPLICATION OPTIONS: HARDWARE... the setting from Optimization by IV,
to Override recommended setting - Full Optimization. The problem is
corrected.
-Kerwin
