The CADWhisperer YouTube Channel
@nstalker wrote:
I ran into this error and fixed it by changing my extrusion to be a new solid.
Is that really really the solution? Depends!
Attach your file here.
I'm facing this problem when I try to extrude some faces. I have a sketch, and an offset of this sketch. I made thiskind of 3D makette a lot of times (cookie cutter), and they works. But this time I can't extrude the offset. I tried to extrude it as a new solid, in that way it works, but then I can't add a good fillet to the meeting point/line of two solid faces.
What can cause this problem, and what can I do to avoid it?
Thank you very much.
" The feature as specified did not change the number of faces (and may not have affected the part). Accept the feature that resulted, or use Edit Sketch or Edit Feature to change the feature definition."
Sorry, it' inventor professional 2016
Extrusion25 works, but the others are just as new solids. On the borderline of extrusion 25 and 29 I can't make a normal fillet.
Thank you 🙂
Your file works fine for me, but if you want to use as is, do a Combine to combine all of the solid bodies into one before doing the Fillets.
You should install the Updates for 2016 while they are still available.
Ohhh my.... I guess I've found the problem. In my other sketches I always draw on the xy plane, and this I used another plane. I guess because of this was the error that not changing the number of faces...
This was one of my first sketch, and now when I wanted to update it with my new observations, I've found this error.
So when the problem occurs, and I use the new solid extrude, then the fillet, I get the the "wrong" fillet, but without the problem, I can use the extrude, then fillet, and I get the good fillet.
Thank you very much. Yes, really, it didn't come to mind to combine them. And thanks for tip about the updates, I will look at it. 🙂
Hi!
I seem to be experiencing the same problem trying to revolve a cut and I don't know what I've done wrong.
I have attached the file to this message if you could help It would be great.
I use inventor professional 2020
Thank you
Hi!
I seem to have the same problem trying to revolve cut but won't let me.
Could you help me, please?
Thank you
Attachment file below..
Thank you sir,
Your right there wasn't much of an issue, I fixed it by selecting two profiles around one axis.
The profile I should have selected was the inner surface and the outer sketch lines for it to work in this case.
