We use multiple sheets only in case when 1 sheet is has not the sufficiënt space for showing al details of an assembly-drawing.
I'm wondering why the "Update all sheets" icon is allways visible when using more then one sheet in a drawing.
René
Solved by Curtis_Waguespack. Go to Solution.
Solved by bobvdd. Go to Solution.
Once you have more than 1 sheet in the drawing the command becomes active and will remain active (as long as you don't turn on "Defer updates" in the document settings) .
I don't think it has the ability to tell you wether an update is actually necessary or not. I think you are expecting too much of the command 🙂
Although I perfectly understand your confusion. I would also like the Save button to get disabled when no save is necessary in a document that I have open. But even Microsoft Office does not offer such a nice touch...
Bob
So, usually, one can tell from the icons that there is an update available but not when you have two sheets. And that is expecting too much of the command? How
It falls into a category of "the lights are on but nobody's home" for sure. Now I know that the Update icon has no meaning once there are two or more drawing sheets in a file. And for all those years I was thinking that the Inventor is telling me that the model has been updated...
Thanks, Bob.
Bob
The command is only meant to give you the chance to force an update of the one or more views that you have selected. In 99% of the cases this is not necessary and Inventor updates existing views automatically when there is a change. It is just in those 1% of the cases where Inventor does not do it for you , to get the views right.
Bob
Who is confused, the customer! Having used Solidworks prevously I see inventor riddled with stuff like this. Has it updated all sheets? then switch it off! LIke with one sheet - still confused? To be fair I am confused myself - where is the SOLUTION.
In Inventor lingo..
"It's pretty simple, there is a button that works differently depending on the number of sheets on your drawing.. If you only have one sheet, and it meets the" 1% of the cases rule" , then the Update All Sheets button highlights. If you have more than one sheet, then the button also highlights, but not so you can update them, or even to let you know that they need updating. It simply highlights to let you know that your multi-sheet drawing has more then one sheet.
Visit this Idea page link to provide feedback to improve this:
@ToddPig wrote:
... If you have more than one sheet, then the button also highlights, but not so you can update them, or even to let you know that they need updating. It simply highlights to let you know that your multi-sheet drawing has more then one sheet.
Hi ToddPig,
I just wanted to provide some clarity to the misconception that this button is not updating the sheets.
When you click the button it does update each sheet, but:
I hope this helps.
Curtis
