Inventor Forum
"Un-Author" a Tube & Pipe Fitting
10 REPLIES 10
Message 1 of 11
mpatchus
1281 Views, 10 Replies
I have a couple of users who accidently added connections to the wrong parts and made them fittings.
For the life of me I cannot remember how to turn them back into regular Inventor parts.
I've removed the connection points, but the parts still appear as fittings when placed into an assembly.
Anyone care to help this tired old brain out?
Thanks in advance... Mike
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
10 REPLIES 10
Message 2 of 11
cwhetten
in reply to: mpatchus
Does it work to just delete the work points and axes that are created by the authoring process?  I've never had to deal with the problem you described, but if I need to re-author a fitting, this seems to work.
Message 3 of 11
cbenner
in reply to: cwhetten
Yes, removing the work points and axes will effectively un-author the fitting.  If it has been published to the CC, you'll have to either delete it from there and republish it,... or do a "replace family template" on it.
Message 4 of 11
mpatchus
in reply to: cbenner
I've removed the work points and axes completely from the part, saved the part to our library, and checked it back into Vault.
When I insert the part into an assembly it still comes in as a fitting.
Also any existing assemblies still show the part as a fitting.
I'm stumped.
Inventor 2025 Beta
Message 5 of 11
cwhetten
I tried your part and it shows up as a fitting for me, too.  Doing a "Save As" had no effect.
Once it was placed into an assembly, if I did a copy and paste to add a second one, the second one shows as an ordinary part...  Probably not an acceptable workaround, but it's interesting behavior.
I couldn't find any more info on this, so I'm stumped.  There must be some switch buried in the part that tells inventor that this is a fitting.
There may be something in the API that will let you hack the part open to toggle it back to a normal part, but that's foreign territory to me.
Message 6 of 11
NicolasXu
Besides the work features, there are some attributes are added by the Authoring process. There is a solution to remove Tube and Pipe authoring from part, please take a look.
http://usa.autodesk.com/getdoc/id=TS13404549
Nicolas
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 7 of 11
mpatchus
in reply to: NicolasXu
Thats it Nicolas!!!
Thanks so much!
Inventor 2025 Beta
Message 8 of 11
cwhetten
Hah!  That's great!  Thanks, Nicolas.  That was too hard to find, but I forget to check the knowledge base site for things like this.
Message 9 of 11
cbenner
cwhetten et al...
Copying and pasting a fitting, while in the tube & pipe system... is a baaaaad idea.  it may not do anything outside of routed systems,... but in tube & pipe, it will result in you NOT being able to ever delete that fitting.  Strange, and I assume, not intended behavior.  Sometimes, "restore fitting" will get rid of it..... but usually the only fix is to delete the entire pipe route and start over.
Just thought I'd add my two cents....
Message 10 of 11
milan5
Can you link again it is not working?
Milan
Message 11 of 11
IgorMir
Here is a piece of code, which does it. It is not my one. I just found it on this forum a few years ago. Unfortunately - I didn't make a note of it author than. But my thanks to him is still valid and current.
Cheers,
Igor.
Sub RemoveTPAuthoringInfo()
Dim oProperty As Property
Set oProperty = ThisApplication.ActiveDocument.PropertySets.Item("32853F0F-3444-11d1-9E93-0060B03C1CA6").ItemByPropId(56)
oProperty.Value = ""
End Sub
"Thank you to use Tube and Pipe Authoring tool. There is no direct way to remove the authoring info. Here is one attached .txt file containing VBA code, which will help to remove all authoring info. Steps are as below.
1. Open the authored part .
2. Copy code vba code to VBA editor and run it."
Web: www.meqc.com.au
