Inventor Forum
"The active project cannot be changed while Inventor files are open"
9 REPLIES 9
Message 1 of 10
1432 Views, 9 Replies
I close all files, try to change projects and I get this message, "The
active project cannot be changed while Inventor files are open".
I have to close Inventor and restart to change Projects.
Russ
9 REPLIES 9
Message 2 of 10
shaney
Do you have an embedded spreadsheet open in Excel when this happens? I had to close an embedded spreadsheet before to avoid that message.
Message 3 of 10
No excel spreadsheet open here. Not sure what is up, I had this problem last
week. Never happened before.
Thanks for the suggestion.
Russ
wrote in message news:5451972@discussion.autodesk.com...
Message 4 of 10
I also start another session of Inventor and I assign to it a different project.
Message 5 of 10
Bad practice... Projects a tracked by Windows, and Windows can only track
one project at a time. If you are working on assemblies, you can screw up
links.....
Inventor AIP11 sp2
Dennis Jeffrey, AICE, MICE
Center for Design Excellence
260-312-6188
wrote in message news:5452016@discussion.autodesk.com...
project.
Message 6 of 10
shastu
I have had this happen a number of times with 2008. If anyone could figure out why it is not recognizing that all files are closed, I would be interested.
Message 7 of 10
I've had exactly the same error with 2008 even theough no files are open.
Mike
wrote in message news:5674891@discussion.autodesk.com...
interested.
Message 8 of 10
In Inventor 2008, is the Close All command available under the Files
pulldown? If that does not work, you may still have a .lck file present.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
interested.
Message 9 of 10
Many thanks Dennis!
I had one file that would not 'let go' of Inventor 2013 and the 'Close All' command did the trick.  I was getting tired of closing and re-starting Inventor.
Thanks again!
Message 10 of 10
cbenner
@Anonymous wrote:
Many thanks Dennis!
Thanks again!
Welcome to the group dwing.
Dennis was one of the all time greats in this group, if you find any of his posts from years past, I guarentee you'll learn from him as we all did.  Sadly Dennis left us a few years ago.  The rest of us do what we can to help out so feel free to ask whatever questions you have.
