Inventor Forum
"rounddown" command?
3 REPLIES 3
1762 Views, 3 Replies
Is there a command for "rounding down" numbers when working with parameter
equations???
For example, I want to use this equation to determine the number of mounting
holes in a variable length part: # holes = ((overall length - (dist from
end x 2)) / rough hole spacing) rounded down
I will then take this "rounded down" number and use it to determine the
spacing between holes: hole spacing = (overall length - (dist from end x
2)) / (# holes - 1)
I know this can be done by linking to an excel file but I thought there
should be a way to accomplish these equations in IV without having to link
to an excel file.
Is there a better way to accomplish this???
Scott
3 REPLIES 3
try the function ceil. Look on www.sdotson.com for a pdf explaining all the
functions in inventor.
Kathy Johnson
"scott peebles" wrote in message
news:2AEA312D12675C6C0EF00007BA6D56C7@in.WebX.maYIadrTaRb...
> equations???
mounting
> 2)) / (# holes - 1)
> to an excel file.
> Thanks
> Scott
Actually wouldn't it be floor that he wants.. .. unless I am reading it wrong.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"KJohnson" wrote in message
news:9D857514D2FD8B307FBC5494D0D33162@in.WebX.maYIadrTaRb...
Yes you are correct. You also must have the function in the brackets as
coming out as unitless. Then multiply the floor()*1in or whatever.
Kathy Johnson
"Kent Keller" wrote in message
news:44F056DFC94CFA390842A91D91E41C56@in.WebX.maYIadrTaRb...
wrong.
> Kent
the
