I'm a novice Inventor 2012 user trying to draw some sheet metal parts for use in our plant. I've been able to create most of the parts I need except for one. I have a triangular-shaped piece of sheet metal that needs to be rolled so that it has a specific radius. This part will in turn be attached perpendicular to another piece of sheet metal with the same radius. I've messed about with the contour flange, but that only seems to work with open sketches. Can anyone please help with this one? I've been reading similar needs on this forum for the last couple days, but cannot find anything that I can get to work. I've included an attachment to help the explanation.
Thanks in advance!
Solved by CCarreiras. Go to Solution.
CarlosC. That appears to be it. Can you explain how you created the drawing? I know the radius of mine needs to be 17.50625 (calculated). The triangular piece is 12.5 inches long by 2.75 inches tall and the arc has a 48 inch radius.
MichaelS
Hi!
Let's go...
First draw a arc with the radius=17.50625 and lenght:12.5. Full constrain the sketch with constrains and dimensions.
Apply "Contour flange" With 2.75in
Be aware about the side of the thickness grow...
Unfold the part, select one plane in the edge and one curvature face:
now the part is flat, cut the square too achieve the triangle: make a sketch in the flat face and use "Cut" tool to create your triangle:
Exactly what I needed, CarlosC! Let me say that your method was a lot easier than anything I had thought to try in the last couple days! One last thing...I've tried to create a drawing file of this part. I would like to show it unfolded where I can dimension it flat for the person making the part as well as folded. When inserting the "Base" part there is a Sheet Metal View option where the default is set to "Folded Model". There is also an option for "Flat Pattern" that is greyed out. Am I doing something wrong where it is hiding that option?
MichaelS
Hi!
You have to perform a flat pattern in 3D before you document it in the drawing.:
Open again the 3D Part and perform the flat pattern, save and go again to the drawing, now the flat pattern isn't grey out.
Got it! I was confusing the unfold and flatten pattern commands. Works great and I can even add the flattened and original curved parts into the same drawing. Thanks for all the help with this one!
Hi!
You can have only one "accept as solution", so if some post solve your problem you can accept it as solution, maybe chose the first of the tutorial post.
Kudos, you can post where you learn something good, it's up to you.
