Thanks, Charles. That was it.
"Charles Bliss" wrote in message
news:3DC745C0.3040706@cbliss.com...
You most likely have an add-in running which is causing some problems.
First suspect would be the Content Library. Look through Addins and
turn them all off then enable them one at a time until the behavior
reappears. Leave the bad guy off.
James H. Moore wrote:
> Every time I close Inventor (whether using File > Exit or the close window
> button), I get a "Program Error" message, stating "Inventor.exe has
> generated errors and will be closed by Windows. You will need to restart
> the program."
> Anyone else experience this?
> -- James
