My .ipt file has a shared sketch that is visible and not adpitive.
But When I attempt to make a second extrution from the sketch, a message says, "No visible, unadaptive sketches".
I could create another sketch, but I want to learn how Inventor is woking becuase I have had this error before.
The file is attached (I am trying to extrude from the "binder" sketch).
Thank you.
Solved by samiharada. Go to Solution.
Solved by cwhetten. Go to Solution.
I just tried it and it worked for me. Although in the part you attached, the binder sketch was invisible, so I had to make it visible first. But I don't know why it won't work for you...
Cameron Whetten
Inventor 2012
Turn visibility on first?
I see both "tube" and "binder" are invisible - the message says "No visible, unadaptive sketches"...
-Sami Harada
Inventor framework QA
Now I understand; "visible" doesn't just mean I can see the sketch, it means "Visibility" has a check mark.
Thank you for getting me through this newbie question.
