Inventor Forum
"miter" in "Frame Generator"
4 REPLIES 4
emaiolino
399 Views, 4 Replies
Good morning.
In a structure with a curved part, I can not properly perform a "miter" between the shape.
Attached two images.
Anyone know how to fix, for each IPT properly and to make constructive IDW of each??
Esteban Maiolino
Titular EMBA Proyectos
Sitio web o nombre del blog
Facebook | Twitter | LinkedIn
4 REPLIES 4
CCarreiras
in reply to: emaiolino
Hola.
I think the issue is, the parts aren't perpendicular between each other... Maybe you have to construct a plane and cut the members using the plane.
Be careful with the sizes in the part list for these two members, because if you cut the elements with an outside tool from frame generator, it can give you a wrong total dimension.
Saludos.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
emaiolino
in reply to: CCarreiras
Dear Carlos, thank you very much for your reply.
I can not fix it.
Estimado Carlos, muchas gracias por su respuesta.
No logro solucionarlo.
Esteban Maiolino
CCarreiras
Hi!
Can you post the files? Maybe i'll find a way.
CCarreiras
emaiolino
I solved it!
Generating a small lie in the Sketch, becoming the first straight section (in this case only 20 mm), it is not real at all but would help fix it!
Lo solucioné!!!
Generando una pequeña mentira en el Sketch, haciendo el primer tramo recto (para este caso sólo 20 mm), no es lo real del todo pero ayuda a solucionarlo!
Esteban Maiolino
