Inventor Forum
"include All Surfaces" in drawing with Assembly with Sub assemblies
10 REPLIES 10
Message 1 of 11
BL4849
1070 Views, 10 Replies
Inventor 2013
Issue: Using Parts created with "As Application surfaces" (only to aid positioning in assemblies). Main assembly built up from sub assemblies which include these parts have the issue on the displaye views in the drawing. When creating drawing views of the Main assembly the application surfaces cannot be hidden by deselecting the "Include All Surfaces" option on each assembly view.
They can be hidden as, shown with an assembly made up only of parts.
See Pics
Any ideas?
10 REPLIES 10
Message 2 of 11
CCarreiras
in reply to: BL4849
Hi!
Yes, it's painfull somethimes.
What I used to do:
Make some reprresentation views in the assembly and hide the surface parts. Then create your views based in that represention views.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 11
BL4849
in reply to: CCarreiras
Not sure what you mean.  How do you "hide the surfaces" in the 3D assembly ?  The "surface parts" are part of individual parts.
Message 4 of 11
CCarreiras
in reply to: BL4849
Hi!
Even worst... you have to go to the parts, edit, and turn the surfaces invisible... save and check again.
To avoid this issues, when no long need the surfaces as references, I turn them nvisible immediatly
CCarreiras
Message 5 of 11
Why did they do this anyways? in 2012 this wasnt a problem?
Message 6 of 11
CCarreiras
Have You all service packs installed?
CCarreiras
Message 7 of 11
BL4849
Latest (update2) installed.
Message 8 of 11
CCarreiras
in reply to: BL4849
Hi!
 You´re trying to do this in the assembly, but the surfaces are in the parts. Do it in the parts which  have surfaces or open the parts and turn the surfaces features visibility off.
CCarreiras
Message 9 of 11
BL4849
I know what you mean.  Its not really practical since I have 40+ repititions of some  parts (each with several surfaces) in the sub assembly.
The only way is to manually turn each individual surface by editing the part in the sub assembly of the main assembly.
I was hoping there was a "one click" solution.
Message 10 of 11
t_pcoll
in reply to: BL4849
can you please try/verify your view is NOT using Associative design view? Please, RMB on the VIEW13 ->Edit View...->Uncheck Associative checkbox.
Ladislav
Message 11 of 11
BL4849
in reply to: t_pcoll
Thanks very much.  I did have the "Assoiciative" box checked.
Seems to have fixed this problem.
