Inventor General Discussion
Product Support
bobvdd
Message 11 of 13 (151 Views)
Re: "Houdini Disappearing Act" when using Break View
08-10-2012 01:47 PM in reply to: kwilsonamerex
Kenny,
I have good news for you. We double checked and your issue is solved in the upcoming 2013Sp1.
Meanwhile there is a slightly less annoying workround than closing the Inventor session:
  • Open the drawing file
  • Open the assembly file (Update the assembly if you get an update dialog)
  • Switch to the drawing file and the break should behave OK.
bob
kwilsonamerex
Message 12 of 13 (137 Views)
08-13-2012 05:43 AM in reply to: bobvdd
That's GREAT news Bob!!
I will try your other workaround. Beats having to close and re-launch :smileyhappy:
Thanks a ton!!
Kenny
Corsair 900D ♦ ASUS Maximus VI Extreme ♦ i7 4770k ♦ (3) GTX 780 Ti's ♦ Trident X 32GB ♦ Samsung 840 Pro ♦ WD 1TB Black ♦ SG 1TB ♦ Corsair H100i ♦ Corsair AX1200i ♦ many SP120's
PDS 2014 ♦ Vault 2014 Pro ♦ CFD 2014 ♦ Bunkspeed Pro 2014 ♦ Octane Render ♦ Certified Autodesk Inventor Professional ♦ CAD Manager/Design Engineer
If this post solved your issue please mark "Accept as Solution". It helps everyone...really!
New Member
jannik.mortensen
Message 13 of 13 (58 Views)
11-28-2013 03:03 AM in reply to: bobvdd
We have the same problem in our company. Running PDSP 2013 and PDSS 2013 on roughly 40 workstations. We can reproduce the same error on 4 different Dell workstations and the 4 different graphiccards.
We have installed SP2 update 3
It an annoying issue for us. When will Autodesk solve the issue?
KR
Jannik Mortensen
Need installation help?
