Daniel,
If you look at the system requirements for 2011, Windows 8 is not even listed. That might be part of what your issue is.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Half joking here, but:
Install IV 2011
Has the four days you have spent trying to get this to work been worth $134?
I don't understand why you are trying to use an unsupported OS for your version of Inventor.
See the following link for a list of Inventor Versions and suported Windows Versions
Steve Walton
IV 2011 is my shorthand for Inventor 2011.
Normally installing IV is easy enough, you have gotten caught by the changes to the OS that Microsoft made between Windows XP/Vista/7 and Windows 8. Think of Apple's change form MacOS to the unix based OS. Or maybe the transisition from PowerPC to Intel processors.
Autodesk has worked to support Windows 8 with IV 2014 as the first version. IV 2015, which does not have an announced release date, should be better. Over the last few years, the new version of IV comes out in late March/early April. That version should install much smoother.
Steve Walton
Hi! Like other members have pointed out, Inventor R2011 does not officially support Windows 8 (8.1) unfortunately. I do have a question for you. The subject title of this thread is about "File corruption" but the message says about R2011 failing to install on Windows 8. I am not entirely sure the two are the same issues. Are you sure they are related? Do you have an example showing the file corruption issue?
Thanks!
Hi johnsonshiue,
danielneuhaus has created multiple posts on this issue, so there is some extended information on those threads:
Related threads:
http://forums.autodesk.com/t5/Inventor-General/installing-inventor-2011/m-p/4874064#M500270
I hope this helps.
Curtis
