Im having the same problem!!! ERROR LOADING SEGMENT AMDCSEGMENT IN DATABASE. IM GETTING CRASY!!!
Can someone PLEASE help me!
Hi! The error indicates the Inventor trying to open the file considers the file corrupted. What Inventor release are you on? What Inventor release was the file last saved? Please note that Inventor is not yet capable of opening files saved in newer version on an older version. Could you provide the files you are having trouble with (send to johnson.shiue@autodesk.com)?
Many thanks!
El error se produce por que hay piezas en las cuales se han realizado análisis de tensión y estas han sido copiadas de un proyecto a otro, la solución que he encontrado yo a este problema es identificar los elementos que tienen análisis y eliminar este análisis dentro del módulo "Entornos"/Análisis. Con esto debería poder permitir grabar el ensamble.
Hi! Like my older reply indicated, the error message means the file is corrupted. The design capture segment can no longer be read. Unless we know how to reproduce the corruption from scratch, there isn't much we can do. Are you using a file management system or file encryption system?
Many thanks!
