Inventor Forum
"Error in reading RSe Stream" and more issues! Inventor 11
12 REPLIES 12
Message 1 of 13
2824 Views, 12 Replies
My computer went down two weeks ago, bad enough that I had to get a new hard drive and start over. When I went to install Inventor, I kept getting Errors 1335, 1334, then error 1406 during installation. I seemed to have gotten beyond those, but when I went to open certain assemblies I started getting "Error in reading RSe Stream (4 not equal 2)" and "Error in reading meta types in RSe Segment AmDcSegment in..." and them it shows a certain file it doesn't like, sometimes repeating for multiple files. I clicked on the communication icon in the lower right of my Inventor screen and it said a maintenance update was available. I installed SP1 and tried again. Same problem. I clicked on the icon again, and it told me SP2 was available. I installed it and tried again. Same problem. I clicked on the icon again, and it told me SP3 was available. I installed it and tried again. Same problem. I clicked on the icon again, and it told me SP4 was available. I installed it and tried again. Now I can't open Inventor at all. Inventor crashes just on trying to open up. I've been running Inventor 11 since it came out with no issues whatesoever. Now I'm two weeks behind with no end in sight. Can anyone shed light on this for me?
12 REPLIES 12
Message 2 of 13
Was any Anti-Virus software on your machine prior
to installing IV? What version of O/S are you using?
IV2009-Pro Sp1
Dell 670 dual Xeon - 3.2
3gb memory,
SCSI320-15k rpm
XP-Pro, sp3
Quadro FX3400: Driver: 174.06
Direct3D
SpacePilot Rel V: 3.6.7 Dvr V: 6.6.1 Firmware 3.12
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
My
me?
Message 3 of 13
I seem to have fixed the issues of not being able to load up, but am still running into the "Error reading RSe Stream (4 not equal 2)" on random files. I'm runnning Windows XP, have no antivirus installed and the firewall is turned off. I can't find this error on any searches on the net- no one seems to have had issues with it but me? Any help in this matter would be greatly appreciated.
Message 4 of 13
I am thinking that somehow this install is bad. I
would un-install IV along with ADMS and all related directories
XPsp2
Log-in as Administrator
Register Excel by running it
Install IV and register
Install IV sp's
IV2009-Pro Sp1
3gb memory,
SCSI320-15k rpm
XP-Pro, sp3
Direct3D
I
appreciated.
Message 5 of 13
Thank you for the suggestion- I tried that last week- came up the same. What is most odd to me is that my co-worker, who did not have any issues prior to this fiasco, also has the same error come up when he tries to open the same files I have had issues with. It's almost as though some of the files have somehow corrupted themselves, but at random. I'm so ready for this mess to be done.
Message 6 of 13
That CAN happen if they wer on the bad hard drive. Have you
had someone try a File Recovery on the old drive?
Dennis Jeffrey, Autodesk Inventor Certified Expert
Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App
Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000  AMD64
2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver
Theme
http://teknigroup.com
Thank
done.
Message 7 of 13
I have not tried that- Once I got a rreplacement drive working I was able to view the other drive in Windows Explorer and copied over our whole Inventor file base to a new Network Drive. Most files seem to be working fine- it "just happens" that the files I REALLY need to work with right now are the ones causing problems. Suggestions?
Message 8 of 13
File Recovery software $50.  Real cost PRICELESS. I
recovered an entire 250GB Drive that got corrupted..... saved my
bacon!
Active File Recovery and Active Partition Recovery at
href="http://www.file-recovery.net">http://www.file-recovery.net
I ended up having to buy both Softwares in order to do a full
recovery of the entire hard drive.
Engr.
HP zv5000  AMD64
2GB
Theme
I
Message 9 of 13
Wow. Thank you very much- I'll look into that. This past couple of weeks of trial and error and error and error, etc. has been so frustrating. Things like this never happen when there is nothing to do, only when you're already in over your head. Thank you all for your input. We'll see what happens.
Message 10 of 13
Or do full back-ups every day.
IV2009-Pro Sp1
3gb memory,
SCSI320-15k rpm
XP-Pro, sp3
Direct3D
Wow.
happens.
Message 11 of 13
Engr.
HP zv5000  AMD64
2GB
Theme
IV2009-Pro Sp1
3gb memory,
SCSI320-15k rpm
XP-Pro, sp3
Direct3D
Wow.
happens.
Message 12 of 13
yordi1goc
I also have the same problem. An error message as this "Error in reading RSe Stream" appear when I try to open random assemblies. I have Inventor 2012, and I tried to open one of my files on one of my university computer and appear that really annoying message!!!!! What is going on :s
Message 13 of 13
ggrefer920
in reply to: yordi1goc
I have the opposite issue, we use 2012 on the windows XP Dell Insperon computers at school, and I tried to install Inventer 2012 on my windows 7 desktop ( same prosseser ,Intel Core I5) but i kept getting "The application was unable to start correctly (0xc000007b)." So I gave up, now have 2011 installed and I get "Error in reading RSe Stream'" when i try to open anything saved using 2012.     Any Help would be Greatly Appreciated
