Inventor Forum
"Error in Inventor Undo Folder: Please Make Correction"
4 REPLIES 4
rwbal
11485 Views, 4 Replies
I installed Inventor 2013 educational on my Surface Pro running Windows 8 Pro a few weeks ago. It was working fine, until now. Whenever I try to open the program, I get a popup with this message:
"Error in Inventor Undo Folder: Please Make Correction'.
error
I have changed the undo directory to C:\undo, a folder which I created. No matter what location I use, I can't get past this error. I have ran the program as administrator with no luck. Any ideas on how to fix the issue?
4 REPLIES 4
cbenner
in reply to: rwbal
karthur1
in reply to: rwbal
Check the amount of free storage on your c:\.  You might have to do some housekeeping to make more room.
rwbal
in reply to: karthur1
I probably should of thought of that considering the lack of storage space on my Surface Pro. I changed the undo folder to a location on my SD card, and it worked fine. My C drive had around 800MB left, and I didn't realize the undo folder required so much space.
simon.depauw
Tanks i just had the same problemen 😛 and now quicly solved
didn't realised my HDD was full 🙂
